General Settings
General Settings
You can make other changes from this tab such as Donation Section Title, Donation Button Texts, Enable / Disable App, etc.
Additionally, you can make widget customization to match your brand by adding Custom CSS from the “Additional CSS” Option.
You can even Enable / Disable the Thank You Pop-up which appears in the Front end when someone clicks on the Donate Button and changes that thank you message too.
It will also allow you to Enable / Disable to send the Donation Receipts to your customers & yourself / admin.
Add Emails to CC
Customize your Email Template as per your business needs
