Can I add multiple donation Options?
Yes, you can add Multiple Donation Options. This feature is available in the Advance Plan of the App.
Charity List / Donation Options
By default, you can create the option based on your preference and link up the Organization inside the Donation Description.
You can create as many Donation Options (Different Charity) as you want, this feature is available in the Advance Plan of the App.
Will the App work with any of the themes?
The App will work with any of the themes, either its Theme 1.0 or Theme 2.0.
Will the App work if I have changed a theme?
If you have switched the theme, you need to configure the App there on a new theme.
- Identify if its Theme 1.0 or Theme 2.0
- Configure the App to theme
Can we collect donations as a % of product amount?
By default, the app only allows you to collect donations with a fixed amount.
Can we share some % from the cart value to the Charity?
Unfortunately, the donation values will be predefined or custom amount as per the user’s choice and hence it won’t be possible to share some % from the cart value to the Charity.
No, App does not have any extra charges than the Recurring Charges on a Monthly basis on your selected plan.
Can I create multiple donation landing pages?
Yes, you can create as many as donation landing pages you want to create.
Can my customer / Donor choose how much they want to donate?
Yes, users can choose how much they want to donate.
You can enable below option from the App Back end inside Manage Donation
